26 baja 468 bravo part out >
Old 01-13-2013 | 02:25 PM
Sick Stinger's Avatar
Brotherhood #1
Default 26 baja 468 bravo part out
1987 Baja 265 sport. Has a 468 50 hours on it. Gimbal bought brand new in 05 with 50 hours. Bravo drive 24p bravo 1 prop.
Motor is a 468 comp cam pro roller rockers 10qts oil pan holley carb dart iorn eagle heads gil/harden manifolds and risers pro billet msd dist. and soft touch rev limiter valve covers a bit rough, i will pull them and powder coat if wanted to color of choice. Ran the boat right around 70 never dyno'd but guestimate of 475 or so. Couple was also new with 50 hours. Steel trailer load rite with title brake inop but set up for it. has alloy wheels new tires bearing and seals just done.
Attached Thumbnails 26 baja 468 bravo part out-baja1.bmp   26 baja 468 bravo part out-baja10.bmp   26 baja 468 bravo part out-baja11.bmp
26 baja 468 bravo part out-baja2.bmp   26 baja 468 bravo part out-baja3.bmp   26 baja 468 bravo part out-baja4.bmp
26 baja 468 bravo part out-baja5.bmp   26 baja 468 bravo part out-baja6.bmp   26 baja 468 bravo part out-baja7.bmp
Sick Stinger is offline
Old 01-13-2013 | 02:31 PM
Brotherhood #1
I haver a picture of a differant throttle shifter set up in the prev. post, those can be offered with the boat to replace the quicksilver stock 1 piece shifter. I have a rocker switch i will thrown in with it for drive trim. Boat has reupostered interior with exception of the sunpad. Alpine radio with remote cd and a set of 6x9 speaker in rear seat bennet trim tabs. Boat can be bought less power on trailer or just hull interior with no drive/ transome assembly and or with with out trailer. Has 3 monster gauges pro comp marine autometer speedo tach and water temp other gauges stock. can get any more pics you need or want
Mike
Old 01-13-2013 | 02:41 PM
i have a friend with a 90 dvx,,he broke the sliding door and some broad put her foot through the plastic piece next to the door...how much for both pieces?
FIXX is offline
Old 01-13-2013 | 07:29 PM
Brotherhood #1
I'd like to keep the boat whole as of now but will let you know
Mike
Old 01-13-2013 | 09:03 PM
How much for the gimble and the 24p bravo?
Sunrocket24 is offline
Old 01-14-2013 | 05:15 AM
Interested in the gimble and prop.
Jeff
sbslinde is offline
Old 01-14-2013 | 08:07 AM
Brotherhood #1
The gimbal is great shape the prop is hashed a bit will get pics if still interest
Mike
Old 01-14-2013 | 09:11 AM
Mike you said keep it whole. Boat trailer and gimbal price? Maybe drive as well?
machloosy is offline
Old 01-14-2013 | 09:20 AM
Interior looks decent!
kreed is offline
Old 01-14-2013 | 10:17 AM
Brotherhood #1
Boat and trailer 3000
With gimbal 3500
With drive 4000, ill throw the prop in and shifters leave trim pump and rewire and light the trailel. They work fine but good to have new stuff
Gimbal alone 800
Drive 800
Motor complete bravo drop in includes exhaust 4500 with powder valve covers of choice, less dist.
With full ignition 4700
MSD blue box, soft touch rev, and pro billet 350
