Savage speeds? >
Savage speeds?
Savage speeds?
Old 01-18-2013 | 11:00 AM
Default Savage speeds?
What are realistic top speeds for a savage with a full load, 4 people, cooler, half to 3/4 tank of fuel?
With 500hp, 600hp, 700hp, 800hp?
How much power has someone put in a savage?
Crossett is offline
Old 01-18-2013 | 12:56 PM
A couple of guys on here are running about 800hp..85-90mph
My 500efi should run 70 any day.
Drock78 is offline
Old 01-18-2013 | 01:21 PM
Gladhe8er's Avatar
525 EFI - labbed prop, 1 person, 1/4 tank, perfect conditions - 72.9 MPH GPS
3-4 people, 3/4 tank -67.5-69 MPH usually.
Gladhe8er is offline
Old 01-18-2013 | 01:24 PM
My stock twins are about the same.
abmotorman is offline
Old 01-18-2013 | 01:51 PM
Gladhe8er's Avatar
Maybe OCD will chime in. I believe these are his speeds:
500EFI with procharger(750ish HP): mid 80's
500EFI: 67 MPH
He does have an IMCO drive which probably robs 1-2 MPH.
Old 01-18-2013 | 04:42 PM
who is OCD
My Addiction is offline
Old 01-18-2013 | 04:55 PM
500EFI: 67 MPH
maybe im being a bit optimistic on my speed...
is he running a imco shorty?
Drock78 is offline
Old 01-18-2013 | 04:56 PM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
Do you have a particular hull in mind already? 2004 and later will be a few ticks faster as the hull was tweaked a bit.
Sydwayz is offline
Old 01-18-2013 | 06:07 PM
I do not, and I was unaware that there were differences, good to know though. The newer ones don't have a step, correct? Is it a pad or a notch that makes them a little quicker? I'm still trying to decide if I want a stand up or a sit down boat. If I decide on stand up I think AT wins hands down, I just don't know how much "wave crushing" ability I really need for inland lakes though i'm sure the passengers would appreciate it.
The other hull that i'm interested in is a 29' kryptonite, completely different beast.
Crossett is offline
Old 01-18-2013 | 06:58 PM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
No notch or pad or anything. The earlier ones has more of a rocker in the center of the hull (lengthwise) due to HP of the engine packages of the day. With props, drives, and more modern technology, the straight bottom got a little straighter after 2004.
Sydwayz is offline
