Stillwaters 41 >
Stillwaters 41
Stillwaters 41
Old 03-31-2013 | 04:13 PM
Default Stillwaters 41
What do you guys know about this boat.
Specs say 11000 pounds is that possible with a pleasure
Here are the specs on the motors
Any room for blower motors will they fit
And the drives?
What ever you guys can tell me about it would be great I am interested in it, I like the center steer but unsure about the motors or drives.
TURBO JET is offline
Old 03-31-2013 | 05:14 PM
Only thing I know is I want it! To me it's the best setup to have, full pleasure staggered, beautiful cabin and full cockpit looks great to me.
Unlimited jd is offline
Old 04-01-2013 | 07:34 PM
Does that build sheet say the valves need to be adjusted every 10 hours?!?!?!? Is that normal for engines like that?
macjazzy is offline
Old 04-01-2013 | 08:57 PM
Thanks for picking that out i will ask.
Old 04-01-2013 | 09:11 PM
sean stinson's Avatar
The Illustrious One
Veteran: Navy
That's the best all around performer you could ask for from Apache in a pleasure config.....and yes you should run the valves every 10-20 hrs
Dying,....Is the day worth living for!!!!!!
sean stinson is offline
Old 04-01-2013 | 09:14 PM
Full Force's Avatar
Saw the boat a few years ago in Sandusky when a buddy was considering, was in real good shape, very cool boat!! hope its still as nice.....good luck!
Full Force is offline
Old 04-03-2013 | 08:42 PM
depending on the access, having to adjust the valves that often would kill it for me. Even being a mechanic who can do that type thing myself, that would be a PITA to do on most boats I have ever seen.
macjazzy is offline
Old 04-03-2013 | 09:12 PM
el indio's Avatar
the acess 2 the front motor is tough. third of the front motor is under rear seat.
el indio is offline
Old 04-03-2013 | 09:16 PM
el indio's Avatar
the motors r mounted low. 4s r obsolete need 6s. i made an offer tues based on putting 6s on her..dont think they will take it..if u blowup a 4 u r out of biz..cya..
el indio is offline
Old 04-04-2013 | 08:32 AM
RMPRam's Avatar
Not necessarily, on the "if u blowup a #4 u r out of biz". I have new upper gear sets and new "big" propshafts for the #4 drives. There are still a lot of used parts still out there for the #4. I, personally would not be afraid of a boat with #4's on it. Also, in my opinion, #6's would, granted, make the drives "bullet proof" but they are considerably heavier than the #4 and add the additional expense of a #6 drive and the ultra high priced #6 gimbal. Just my .02 for what its worth. Sorry for disagreeing with you Mark.
RMPRam is offline
