Engine Oil Questions.  What do you think i the best! >
Old 07-18-2013 | 01:03 PM
Cool Engine Oil Questions. What do you think i the best!
If you have read my other thread I had a fuel pressure regulator issue. That is fixed not but not before dumping fuel into my oil. So I am going to have it changed tomorrow but since I have only owned this boat for 2 weeks now I am not sure what oil I should run.
The engine is a Carbed Stroker 496 in my 27 Fountain Fever. I do have a call into the builder but have not heard anything yet.
What do you guys run?? The goods? The Bads? The Ugly's?
Any filter preferences?
I do live in northern MN so It will be changed again in a couple months when it gets winterized. Our air temps are usually between 65-85F every now and then over 90, but that is rare! Humidity can be 40-70% at times thought!!
Thanks, I am slowly learning here!
Chris~
Enforcer27 is offline
Old 07-18-2013 | 01:08 PM
I use Mobil 15w50 if you want synthetic or valvoline 20w50 for dino. Mobil 1 oil filter. Lot's of opinions out there on this That.s just my $.02
RT930turbo is offline
Old 07-18-2013 | 01:35 PM
I run Mobil 1 15w-50 also with an M1-302 filter
Griff is offline
Old 07-18-2013 | 07:30 PM
35fountain's Avatar
Amsoil 20-50
35fountain is offline
Old 07-19-2013 | 04:54 AM
Valvoline racing oil SAE 50
Black Baja is offline
Old 07-19-2013 | 05:06 AM
I use the wix racing filters. 51060R.
Valvoline VR1 is good stuff, and most parts stores stock it.
MILD THUNDER is offline
Old 07-19-2013 | 06:27 AM
Chris, the oils that have been listed are all good, however I am not a fan of heavy straight weights for cooler morning start-ups.
Before this thread is over, you will be slammed with every brand of oil you have heard of plus oils from specialty blenders.
I would use a multi-viscosity product. I personally run a 20w50 in my 454. I would look for a product with a lot of zinc which is a anti-wear additive AND an anti-oxidant.
The anti-wear needs no explanation, but the anti-oxidant is what prevent the oil from getting thicker as time is put on the oil.
It is going to make no difference to you whether you run a petroleum, semi-synthetic, or full synthetic, as you will probably change the oil before any of those particular base stocks start to fail.
You really can't go wrong with the OEM stuff, last time I checked Mercury's 25w40, it had a good slug of anti-wear, but this was 2-3 years ago.
Any modern day oil of the proper viscosity you choose will work fine in your boat.
I personally run this product http://www.spectro-oils.com/motor-guard/ because of the seriously high concentration of zinc.
Hope this helps.
Ken
minxguy is offline
Old 07-19-2013 | 07:51 AM
I used a quality 10w40 And a moroso 2 quart filter
http://www.moroso.com/catalog/catego...?catcode=20002
Mtuned is offline
Old 07-19-2013 | 07:56 AM
28Eliminator's Avatar
I second minxguy, I do run Mobil 1 15w-50 also with a Napa/Wix filter. Some of my friends use nothing but Merc, and a couple use Kendal 20w-50. See what the builder says, but many guys use what they are using because it is easy to get in their location.
28Eliminator is offline
Old 07-19-2013 | 08:31 AM
Joe Gibbs MR50
trannyjoe is offline
