Changed to Amsoil and list oil pressure? >
Old 06-17-2014 | 11:29 PM
Default Changed to Amsoil and list oil pressure?
I was using M1 5/50 and had 65lbs oil pressure then changed to 20/50 Amsoil and lost 25lbs of oil pressure ? What's up with that? Anyone else have this issue? I checked sending unit and it's working fine. I don't understand what happened. Your comments please. Thank you
236eagle is offline
Old 06-17-2014 | 11:39 PM
Rwbrew3's Avatar
I read a thread earlier this week where a bad filter was causing low oil pressure! Just a thought if all you did was change the oil and filter..
Rwbrew3 is offline
Old 06-18-2014 | 08:43 AM
Wobble's Avatar
SORE MEMBER
Certain cheap filters can collapse internally causing that kind of pressure loss. For sure, try another filter before anything else.
Wobble is offline
Old 06-18-2014 | 09:01 AM
Thank u guys so much! It is a Ph5 fram. I will change it! Thank u for your replies
236eagle is offline
Old 06-18-2014 | 10:16 AM
Ph5 fram JUNK man don't run them. Wix or napa gold same filter good stuff
skydog is offline
Old 06-18-2014 | 10:34 AM
And you can generally get an Amsoil filter from the same place you buy your oil.
ALL_IN! is offline
Old 06-18-2014 | 10:35 AM
Got it will do. I will install napa filter and post results. Thank u for your reply
236eagle is offline
Old 06-18-2014 | 10:41 AM
Wobble's Avatar
SORE MEMBER
One other thing, your new oil bottles had an intact seal on them?
I recently was sold some Mobil 1 v-twin synthetic oil bottles that had used oil in them.
Wobble is offline
Old 06-18-2014 | 11:15 AM
Make sure Napa Gold filter :-)
skydog is offline
Old 06-18-2014 | 11:46 AM
[ATTACH=CONFIG]524852[/ATTACH]
Filters are for same application
Attached Thumbnails Changed to Amsoil and list oil pressure?-filter-comparison.jpg
TylerBurich is offline
