Water flow
I am having water flow issues on one motor.
We have changed out the impellor- was perfect., back flushed everything.
Problem is that I am not getting good flow to strainer. One has the water going thru like a toilet bowl and Starboard is just about half that flow.
Any ideas? Changing water circulation pump this week.
Now how? I guess pull drive? I looked at intake holes in nose and they appear clear. We flushed water back out also.
I had this same issue, I put a brand new mercury pump housing on, it had a casting flaw. When I installed it, in between the 2 bolts that are close, the new housing had a hairline small crack, I thought it was a drip from hose, but it wasnt, I replaced with a borrowed older housing. Full pumping, no problems. Just that little air and it made erratic, half pumping situation. Good luck!
What size hose is this? I might just get several feet and replace.
As for the impeller housing its the Stainless steel from Hardin( I think).
Bad part is tanks are Full and I do not want that sitting all winter.
Its Dark back there lol. With the Stellings boxes Hmmm. Need to see about that. Might be able to pull hose lose in box?
