454 with 177 blower build
Old 02-05-2015 | 12:58 AM
Default 454 with 177 blower build
I'm starting this thread to document this build. I have already received much help from some of you, thank you. I've learned a lot on OSO so far and I hope this will give back, at least a little. Long/short is last offseason I built up my engines from stock 365 mags to 475-500 horsepower 460ci & 468ci engines. One engine wasn't stock, it was already .030 over so had to go .060 over on that one. I am now in the process of acquiring the needed parts to successfully add on Weiand 177 superchargers. The parts have started to arrive tonight.
[ATTACH=CONFIG]536569[/ATTACH]
More to come.....
ramos45 is offline
Old 02-05-2015 | 07:25 AM
[QUOTE=ramos45;4260604]I'm starting this thread to document this build. I have already received much help from some of you, thank you. I've learned a lot on OSO so far and I hope this will give back, at least a little. Long/short is last offseason I built up my engines from stock 365 mags to 475-500 horsepower 460ci & 468ci engines. One engine wasn't stock, it was already .030 over so had to go .060 over on that one. I am now in the process of acquiring the needed parts to successfully add on Weiand 177 superchargers. The parts have started to arrive tonight.
More to come.....
[ATTACH=CONFIG]536575[/ATTACH]
Hi, nice work , I have twin stroked 454's
with the same 177 superchargers. It is nice power plant and has 750 hp .
Best of luck with your build.
xxxxxxx1 is offline
Old 02-05-2015 | 07:44 AM
[QUOTE=xxxxxxx1;4260649]
More to come.....
nice numbers.can you tell us more about these engines,things like compression ratio-camshaft and heads.inquiring minds want to learn.
mike tkach is offline
Old 02-05-2015 | 08:46 AM
I'd love to hear the build on 750hp big blocks using 177 blowers
Unlimited jd is offline
Old 02-05-2015 | 09:21 AM
Hey Ramos45, Nice carbs!!! Whats the projected horse power and max. RPM on your motors?
30ftpanther is offline
Old 02-05-2015 | 09:22 AM
Maybe he has 265 AFR heads. If so, I don't think 850ft lbs at 1300 rpm would be out of the question.
MILD THUNDER is offline
Old 02-05-2015 | 09:28 AM
Those carbs are awesome . Good choice on that Ramos.
All joking aside, looking forward to watching this build progress. .
Old 02-05-2015 | 09:59 AM
and the correction factor on the dyno.
sutphen 30 is offline
Old 02-05-2015 | 10:07 AM
Projected hp I hope to be between 600-650, big spread I know but what do I know.....Right now I plan on dynoing the "weaker" of my two motors and then I'll set up the other the same before final tune on water with wideband. I'm thinking of spinning these no more than 5500, we'll see on dyno but I'm a cautious fellow and still get nervous when I hear the truck kick it down a gear up a steep grade when towing, ha.
Screw it, I'll post up on this thread all my current projects. I'll probably be flamed for some but I'm all good with that. As some of you may remember I have a slight trailer issue. Below are some pics of progress with that. Kind of hard to tell but two 20ft long support rails that will be welded to the top of existing trailer frame by 2in spacers, welding is a blast, just learned how to do that too. Oh yeah, one of the driest cities but once I have some raw steel laying around it decides to rain a few days now gotta sand off some rust before painting.
[ATTACH=CONFIG]536581[/ATTACH][ATTACH=CONFIG]536582[/ATTACH][ATTACH=CONFIG]536583[/ATTACH]
Attached Thumbnails 454 with 177 blower build-imag1018.jpg   454 with 177 blower build-imag1041.jpg   454 with 177 blower build-imag1042.jpg
ramos45 is offline
Old 02-05-2015 | 10:15 AM
750 is a STRONG number for a 177 Blower engine to be used in a marine environment. High compression and a big roller will get you there, but in a boat, those things wont work. I had a pair that made 575 each with 9.0 compression, square port heads and comp cams hyd. flat tappet cams. They ran great.
kreed is offline
