Fuel Pump Question 548 ci  with 256 blower >
Old 03-28-2015 | 08:43 AM
Default Fuel Pump Question 548 ci with 256 blower
I'm working on a 540 (548) all refreshed, with a wieand 256 supercharger (dual carb set on on top, Holley blower carbs)
There is a mechanical fuel pump on top of the raw water pump, I believe it is a stocker (and it was on it prior to the rebuilds so it ran that way for some period of time) root cause of failure was a valve dropped into the cyl
the blower pressure is 4lbs ish (not huge boost)
Heads Are grumpy jenkins
Cam jb300 erson
And the engine is stroked...4.25 crank
The combo seemed to work well
Which fuel pump should I be using, I was told that I would need to go electric, I would believe I could get a mechanical that would support it and not have to redo the plumbing
I was told that these engines had alot of hours on them (I also know that they came from a sonic some years ago maybe built in 96 in the past perhaps somewhere on the east coat prior to transplant into the boat that I'm working on now)
welfare racing is offline
Old 03-28-2015 | 09:31 AM
I've never used one, but......
http://www.cpperformance.com/p-12460...6-engines.aspx
MILD THUNDER is offline
Old 03-28-2015 | 10:45 AM
Originally Posted by MILD THUNDER
I have a super charged engine and I went to an electric fuel pump. I installed an aeromotive one and it works great no problems
conneroutlaw is offline
Old 03-28-2015 | 10:48 AM
I sold tigerweldsm a keith eckert mechanical pump that is specifically for that app. They run about $250 new with adapters shipping ect
airjunky is offline
Old 03-28-2015 | 11:17 AM
Just take any Holley pump that screws together and use the bottom half with the mercruiser top half. Works great
Unlimited jd is offline
Old 03-28-2015 | 12:39 PM
I have one of the KE's for sale in the swap shop
snapmorgan is offline
Old 03-28-2015 | 09:36 PM
whats the P/N?
Old 03-29-2015 | 06:35 AM
weldcrane's Avatar
Cv makes a mechanical pump goes right to your see water pump that's a what I use
weldcrane is offline
Old 03-29-2015 | 07:45 AM
personally I never cared for the merc water/fuel pump combo, prefer something like a aeromotive A1000
ezstriper is offline
Old 03-29-2015 | 05:39 PM
there is only 1 battery in the boat, and really dont want to re-plumb the system, so at this point electric is out, as they eat 10 amps combined while running (real world amps)
