X dimension ???
X dimension ???
I have a 30 daytona with twin 525 the bullet of the outdrive is about a half inch under the bottom of the boat. Where should it be, i was told any where from 2 inches under to 4 inches over?? i am looking for top speed. I am hoping for around 110 mph. Thanks
With twins you can be higher than with a single. I have a 26 and am at 1 inch above the lowest part of the hull. ( about 12 inches forward of the transom ) I am installing an IMCO neutral extension box and I am raising it another inch. I did have to modify the drive for more negative trim to get on plane but my slip numbers are 11% at top end and it doesn't blow out when turning with the drive set to neutral. That is with a 4 blade prop.
I would try some -2 shorty's
If you are near Grand Rapids MI I have one -2 and one -3 shorty if you can find another.
Steve
Steve
