Marine Machine steering cylinder seals >
Old 06-02-2015 | 05:54 PM
Russ G's Avatar
Default Marine Machine steering cylinder seals
Need help guys. I have a Marine Machine steering ram that is leaking. I took it apart. The wiper seal and the seal behind that is bad. How do I get the seals out? There is a brass spacer between them. I don't want to damage anything trying to remove them.
Anyone have any seal part numbers?
Thanks in advance !
Russ G is offline
Old 06-02-2015 | 09:51 PM
Rookie's Avatar
It's a pain. Be careful and remember which way all seals and wipers face. I removed them with a pick and had to use a heat gun (low heat) to make them soft and pliable to put them back in. The receipt with the part #'s is for a Qty of 2 rams.
Attached Thumbnails Marine Machine steering cylinder seals-rams.jpg   Marine Machine steering cylinder seals-seals.jpg   Marine Machine steering cylinder seals-ram-part-.jpg
Rookie is offline
Old 06-02-2015 | 10:09 PM
Russ G's Avatar
Thanks for the reply Rookie. I saw your thread. Those part numbers work for Marine Machine rams? Looking into the end cap that the shaft slides though. There is a wiper, part of the stainless steel cap, seal, and brass bushing/spacer. the brass bushing doesn't need to get removed? I can carefully work the seals in there.
Wouldn't there be 4 square o rings for 2 rams?
Russ G is offline
Old 06-03-2015 | 09:38 PM
Rookie's Avatar
They fit my Marine Machine rams. I would look at your cylinder caps and compare to mine in the pic. I believe the 4 O rings you are talking about is the 4 U-Seals on the receipt.
Rookie is offline
Old 03-07-2016 | 02:19 PM
doe's any one sale rebuild kits for the marine machine rams
flashin is offline
Old 03-07-2016 | 02:41 PM
email [email protected] this is one of the old partners emails, he has a lot of the stock left. I have just received some stuff from him last week, great guy.
Pwraddr is offline
Old 03-08-2016 | 08:01 AM
thank you i will shot him a email and see if he can hook me up
flashin is offline
Old 03-08-2016 | 08:12 PM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
Let us know. Sounds like I should buy some parts.
Sydwayz is offline
Old 03-08-2016 | 08:29 PM
He has a lot of stuff. I bought a tilt helm for the AT, another tilt for a friend, got new stickers for the Rams.
Pwraddr is offline
Old 03-09-2016 | 06:28 AM
He has them, 95 bucks. He needs a pic of the cylinder to send the right kits.
Pwraddr is offline
