Power steering pump compatibility question >
Old 06-15-2015 | 11:10 PM
Question Power steering pump compatibility question
I have a mercruiser part num. 849906A28 power steering pump, it looks like a gm pump . Anyone know if it crosses over to another part number? I'm not interested in paying the $675 for a mercruiser pump
amd3073 is offline
Old 06-16-2015 | 06:17 AM
You can use a regular old GM pump you just have to swap out the pressure relief valve.
Black Baja is offline
Old 06-16-2015 | 06:35 AM
Look at one of my post, it is a Cadillac pump from a 4.1 82-85 Seville engine,,,,get this,,,,rebuilt 46.00 at autovalue parts store,,,add a little paint and use your old relief valve,
TWIN-SPINS is offline
Old 06-16-2015 | 07:57 PM
BUP
You have this ^^^^
https://www.google.com/#q=cadillac+4...33684939257996
BUP is offline
Old 06-17-2015 | 09:08 AM
mo3d's Avatar
And this cadillac pump definately works. My 500EFI's pump is weak at idle speeds. Makes it interesting around docks !!
mo3d is offline
Old 06-27-2015 | 09:20 AM
Carbon Footprint's Avatar
What if you don't have an old power steering pump to use the relief valve from? Can you buy the right relief valve on its own?
Carbon Footprint is offline
Old 06-27-2015 | 03:43 PM
We ended up using the one that came with the rebuilt,,,works fine,,,don't know if there is any difference between marine steering,vs,auto relief valves,,,,I still have the pump I took off,,,the relief valve is still on it,,,,,,,
Old 06-28-2015 | 08:26 AM
Good to know, thanks Twin.
Old 06-28-2015 | 12:17 PM
BUP
Pressure ratings are different between the valves for an Auto Saginaw Pump and the marine version.
BUP is offline
