What do these bearings tell you? >
Old 10-08-2015 | 07:27 AM
bck's Avatar
bck
Charter Member#568
Default What do these bearings tell you?
Anything?
Attached Thumbnails What do these bearings tell you?-imag1244.jpg   What do these bearings tell you?-imag1252.jpg   What do these bearings tell you?-imag1251.jpg
Straight bottoms and flat decks
bck is offline
Old 10-08-2015 | 07:50 AM
dirt,iol thin and crank/rods clearances need to be adjusted and trued.
sutphen 30 is offline
Old 10-08-2015 | 08:14 AM
bck's Avatar
bck
Charter Member#568
What about the diagonal/ crosshatch type marks?
bck is offline
Old 10-08-2015 | 08:29 AM
scrotch biting out the poor fit.
Old 10-08-2015 | 08:30 AM
Someone removed bearings rubbed on them with scotch brite and reassembled.
30ftpanther is offline
Old 10-08-2015 | 08:32 AM
SB
x 3.
SB is offline
Old 10-08-2015 | 08:39 AM
bck's Avatar
bck
Charter Member#568
While we're at it.
Attached Thumbnails What do these bearings tell you?-imag1181.jpg   What do these bearings tell you?-imag1179.jpg
bck is offline
Old 10-08-2015 | 09:03 AM
bck's Avatar
bck
Charter Member#568
I think sutphen 30 wins the prize. I didn't want to prejudice the response but the mains in the block were about 5 thou too big (but then why were they scotchbrited?) and hadn't been aligned. We were also guessing the scotchbrite clearance job and I recently switched to a lighter weight oil. Shouldn't have been any dirt though unless it got there during assembly or debris from the damage or possibly a used oil thermostat housing that was put on.
bck is offline
Old 10-08-2015 | 09:17 AM
I have heard of people sanding a little off the back of a bearing to gain a few ten-thousandths in clearance, but to my limited knowledge it is a big no-no to sand the face of them.
Budman II is offline
Old 10-08-2015 | 09:47 AM
If the mains in block were 0.005" to big scotch brite would make it worse.
