fastech cabin bench storage
I'm fairly sure all the fastech cabin bench seats are the same and from the factory, not hinged. I know at least my old 271 and my current 312 are that way. Has anyone ever added hinges to gain storage space beneath them? It blows me away formula didn't do that from the factory. Anyway, if anyone has done this, what did you use? I suppose I would need a hinge similar to the rear bench seat.
I had a 98 312 and removed the head to install an A/C unit. I removed one of the benches to run plumbing and was surprised how little space is actually under there. Even 6 inch fenders do not fit! Don't waste your time cause you'll only be able to put a couple dock lines and a towel under each side.
I imagine that since it's supposed to be an ocean going luxury performance boat that they anticipate it to maybe hit some rough water once in awhile so hinged seats and a locking fastener would be asking for trouble. The closer you get to the stern the smoother the ride is.....so I can imagine in the rough those seats would come undone pretty quick and you would be collecting even more cupholders full of miscellaneous hardware off the cabin floor.
What do you want to put there? DOPE????
