450r/500r
Old 01-17-2017 | 03:30 PM
Default 450r/500r
The outboard revolution continues...........
Attached Thumbnails 450r/500r-450500-745x483.jpg
Skater30 is offline
Old 01-17-2017 | 03:37 PM
Wut? Gtfo here
hogie roll is offline
Better hold your order Dale
MDS
mikesufka is offline
Old 01-17-2017 | 04:00 PM
That is some power, how can those tiny lowers handle jumping out of the water?
Wildman_grafix is offline
Old 01-17-2017 | 04:02 PM
I've confirmed these new motors though two different sources. I can't say for certain when they'll be available, but the picture you see of the 450R and 500R came from Mercury.
Skater30 is offline
Old 01-17-2017 | 04:03 PM
MDS
Don't worry Mike, I never ordered the 400Rs.........I knew to wait until I heard more.
Skater30 is offline
Old 01-17-2017 | 04:17 PM
" I think that was photoshopped by a 400 lb guy in his basement......" PEOTUS
wannabe is offline
Old 01-17-2017 | 04:39 PM
If true that is insane....the 450R I thought we would see in Miami but a 500R.....damn!
Nate5.0 is offline
Old 01-17-2017 | 04:58 PM
Not totally buying the image. Look at the back of the cowl. The 5 in 450 doesn't match and you can see a ghost outline of the "R".
It'd be awesome if it happened but that image ain't them.
freshwaterfiend is offline
Old 01-17-2017 | 05:03 PM
glassdave's Avatar
Neno the mind boggler
not so fast Phil keep in mind all this power is pretty linear through shafts (which easily handle the power) in a straight line only making a direction change a single time at the lower and in outdrives like bravos the upper is the weak link, the lowers are pretty durable, if the lowers on these are adapted XR stuff it would fall within range i would think.
08 OPA High Points Champion
glassdave is offline
