Drive temp guages...???
Old 10-10-2002 | 03:42 PM
jb
Default Drive temp guages...???
Why does Manufac. not put a drive temp guage standard on High performane applications?
I am led to believe that drive temp directly relates to a drive breaking. Not to mention too much HP and doggin the boat hard.
Wouldnt a guage give you an indication someting is near its breaking point???
Also told merc wants NO guage so you CAN break it!
set me straight
jb is offline
Old 10-10-2002 | 04:25 PM
mr_velocity's Avatar
Not so sure about that. I've heard a few drive guys say they have never seen a heat related failure. For Bravos is the constant loading/un-loading of the drive.
mr_velocity is offline
Old 10-10-2002 | 05:04 PM
rick32
Velo !
Load & Unload directly create heat through stress .... Heat is a byproduct of energy, etc, etc ............Come 'on man where you head .......
Rick32
Old 10-10-2002 | 06:31 PM
Raypanic's Avatar
I have them, I like using them, If one drive is not consistant with the other it will clue me in there may be a problem brewing. Someone else just blew a drive because of little or no fluid. I think the indicator would of helped. Either high temp or no temp would signal a fluid loss.
If drive temp is not an issue why do they sell so many drive coolers? It couldn't all be bunk...
Ray
Raypanic is offline
Old 10-10-2002 | 06:56 PM
mopower's Avatar
Toxic FORMULA
A Merc mechanic friend of mine sez a drive shower is the cheapest insurance you can buy
mopower is offline
Old 10-10-2002 | 07:18 PM
Smitty's Avatar
I have had a drive shower (Innovative Marine) on mine since new. I have run it hard always and for the last two seasons I have run 600 hp. with no problems or metal on the magnet. This drive shower is a thick billet type top cap that IMHO strengthens the stock top cap from flexing when you run it hard. I also change fluid every 25 hours along with motor oil. As with ANY internally lubricated machine, heat is the killer of fluids. Heat weakens the fluids thus reducing the gap between things causing metal to metal contact. When the fluid is compromised, that's when things break/wear down.
I feel a drive shower is a requirement for any performance boat and that a drive temp guage is just a way for you to keep an eye on things and practice preventative maintenance by watching temp and changing fluids often. A case of gearlube per year is alot less than a drive repair!!
Smitty is offline
Ken N
Drives and Lower Units
5
09-20-2008 12:34 PM
CheckedOut
0
06-24-2008 12:40 PM
GO4BROKE
Sonic
8
08-22-2007 07:29 AM
Canada Jeff
10
07-19-2007 02:38 PM
Fast Frank
3
08-19-2004 06:28 PM
