Imco sc stronger then a built bravo? >
Old 08-16-2017 | 02:54 PM
Default Imco sc stronger then a built bravo?
are the Imco Sc as strong or stronger then a built bravo base drive?
daniel475 is offline
Old 08-16-2017 | 06:39 PM
The IMCO has a nice case but they contain the same marginal gears as the XR's do
JaayTeee is offline
Old 08-16-2017 | 07:33 PM
NO! But they look cool, so that must mean its faster
class6 is offline
Old 08-16-2017 | 08:14 PM
The IMCO SC has a much stronger case, has a much stronger cap- (stainless steel vs Aluminum and 8 bolts holding it down vs 4), The tower is longer than most tower inserts and tolerances are tighter, at least the ones that I've built were. Is it 2x's as strong? No, but pick up an XR case and then pick up an IMCO case. There is no comparison as to which one has more material in it. Yes the gears, shafts, bearings are all the same, but if the case flexes less which one will hold up better? Not to mention, how much are these other guys charging for an improved tower? Other than that what can they really do to make a stock case better?
endeavour32 is offline
Old 08-17-2017 | 09:29 AM
You can use a Bravo XR upper housing & add Max Machine 11/2 thick top cover for strength.
253 is offline
Old 08-17-2017 | 11:23 AM
Default hey
so basically the SC would be a better thing to go to , can you uprade sc to scx? eventually?
Old 08-17-2017 | 10:15 PM
I've replaced broken prop shafts, vertical shafts, clutch shafts and a couple of lower gear sets, but the things I replace most often are the upper gear sets, which are no different between the two.... these things just don't have that long of a life span....you can't upgrade a SC to a SCX....if that were the case, you would have folks stuffing SCX gears into XR cases
JaayTeee is offline
Old 08-17-2017 | 10:59 PM
Skip EVERY bravo based drive and go straight to the SCX or similar
offshorexcursion is offline
Old 08-18-2017 | 08:35 AM
Default hey
thanks guys I think ill go with a new Imco Sc boats light
Old 08-18-2017 | 09:33 AM
Knot 4 Me's Avatar
I'd seriously contemplate and SCX upper with the SC lower.
Knot 4 Me is offline
