37 AT & 380 tabs
I ran across this diagram in a stack of papers on my desk, so just going to upload it here for others if needed.
Quite a few years ago, I upgraded my 37AT from 280 K-planes to 380 K-planes. If you are going to do so, it's recommended that you "lop the ears" off of them so you don't have conflict/contact with the drives. I did actually have this happen once due to my own negligence. I had tabs down after coming off plane in a shallow area, and then trimmed my drives up a bit too far, and turned the wheel. Fortunately, I had my drives in reverse at the time, and the trailing edge of my prop nicked the inside of the tab; so no damage to the prop, just a quarter-sized nick out of the tab.
These measurements are taken off of one of the boats that Pat installed 380s on originally. This is the starboard tab, so just reverse for the port side tab.
I had a machine shop cut mine down on a proper bandsaw, and then repainted with gloss black epoxy paint to match the rest of the Phantom Black Mercury parts on the transom.
But this particular time that I used the tabs, I knew we were coming off plane into really shallow water. It was only 3' deep or so, and we could see the sandy bottom (in the Keys). I had dropped the tabs while on plane at speed, and pulled the throttles back to "coast in", in neutral. Dropping the tabs keeps the transom from dropping down quickly; so the boat settles just like it raises; flat.
Not really a concern then; as the drives are way past the tabs on your Cigarette.
The majority of the 37ATs are built with the drives direct on the transom, as that's the way Harry Schoell designed and patented the bottom...
...as such that the drives on the transom puts the prop shafts, transom edge, and step on the same level plane.
Pat has but extension boxes and ITS on some boats, but that all requires raised X-dimensions via various methods to match what I describe above. But the boat doesn't need setback to perform.
