Merc 525 EFI Whipple build >
Old 03-31-2019 | 03:54 PM
Default Merc 525 EFI Whipple build
Upgrading my 525 EFI with a Whipple KIT i noticed a spot of rust on the camshaft. So I want to change it.... problem is buying a new one, it’s absolutly a jungle. Anyone have any recomondations as to wich cam to buy, and what else that would be wise to change now that I am at it?
Catchme is offline
Old 03-31-2019 | 03:59 PM
F-2 Speedy's Avatar
Where is the rust on the cam , how many hours on the engine ?
F-2 Speedy is offline
Old 03-31-2019 | 04:45 PM
Engine has zero hours. Rust is on face that hits one lifter. Engine is ‘03 so pulling heads to upgrade to Cometic gaskets.
Catchme is offline
Old 04-04-2019 | 09:25 AM
Talking
Any competent machine shop can polish surface rust off of that camshaft.
I'll pay for shipping if you dont want to use it tho
** EDIT ** Just saw that your in Norway. Shipping could get expensive
c0ncEpT is offline
Old 04-04-2019 | 09:47 AM
F-2 Speedy's Avatar
You have zero hours on a 2003 525 ?? you can use the Felpro PermaTorque MLS gasket a little cheaper than cometic
Old 04-04-2019 | 10:11 AM
Yes, found the unicorn🤪.
Catchme is offline
Old 04-04-2019 | 10:14 AM
F-2 Speedy's Avatar
Well......then you don't need lifters or springs , but I would test the springs before you put it together
I just built a pair of these, going in the boat in a couple weeks
Old 04-04-2019 | 10:36 AM
The valvetrain has been loosened when stored. Pulling heads tomorrow, so will Get a clear vision on the cam. Will probobly run into other minor or major things that requiers your experience, so thankfullfor all inputs and help👍
Catchme is offline
