Cracked 502 block >
Cracked 502 block
Cracked 502 block
Old 06-03-2019 | 12:28 PM
Default Cracked 502 block
what is the difference between my mercury 502 block casting # 14096859 and a regular 502 block? I am looking at buying a brand new block, but all I can find is automotive blocks. Is there a real difference in block design and material. I have heard that my block is heavier than a normal auto 502. does anyone know where I can find another block like mine? New or used? Thank you in advance.
propilot is offline
Old 06-03-2019 | 12:38 PM
SB
there is no normal automobile 502 as none came with them.
double check, but it looks like your's is a gen v 502 block.
14096859 Big Block V8 502, 4 bolt, Generation V
SB is offline
Old 06-03-2019 | 12:41 PM
Gen V marine 502
speicher lane is offline
Old 06-03-2019 | 12:44 PM
I thought there were some 3500 series trucks that had 502s (8.2 liter) around 2008-2010. No?
payuppsucker is offline
Old 06-03-2019 | 12:58 PM
cigrocket's Avatar
No, 496 8.1 liters were made in the early 2000-2006.
Part is 14096859 Big Block V8 502, 4 bolt, Generation V
cigrocket is offline
Old 06-03-2019 | 01:33 PM
SB
nope.
if there where, there would be lots more black stripes down your roads. lol.
SB is offline
Old 06-04-2019 | 05:41 AM
So, will all of my internals will fit in a Gen VI block? Rotating assembly, crank, rods, and pistons. Also the lifter and pushrods? I know a Gen VI block has a 6 bolt timing chain cover and mine is a 10 bolt cover. but other than that, can I put all of my rotating assembly in a Gen VI block? I would like to use a Gen VI block as it is stronger as i understand it.
Thanks in advance,
propilot is offline
Old 06-04-2019 | 09:02 AM
yes, rotating assy will work fine in a gen 6 block
snapmorgan is offline
Old 06-06-2019 | 03:05 PM
Will my heads and intake work off my Gen V block? I would like to use my same heads.
Thanks in in advance again
propilot is offline
Old 06-06-2019 | 03:38 PM
F-2 Speedy's Avatar
Yes........^^^^ the gen VI uses a step nose cam design and a retainer ring that keeps it from walking around, dont think the gen V is like that.
F-2 Speedy is offline
