Question about transom water pickup installation
I have a couple of questions about installing transom water pickups. I am installing them on my 1988 Cigarette 31 Bullet so the boat has a straight hull with no steps. I searched here on the board as well as other places online and it seems that some mount the pickups straight up and down while others mount them at an angle to match the angle of the bottom of the hull. I am sure both ways work but is one better than the other? I have the Hardin adjustable pickups so I will be able to fine tune them, but is there a recommended starting point on how much they should extend past the bottom of the transom? Thanks!
Mine are at an angle, so the pickups are perpendicular to the hull bottom. Flush with hull at the transom, angled down to 3/16” maybe 1/4 below at the rear. My boat is under 70mph so no water pressure issues
Probably not that critical for a single stage pump. However, as the previous post indicated, as you increase your pump capacity you may need to increase the supply.
These homemade ones are feeding three stage pumps that serves oil coolers, heat exch, and intercoolers separate
ly so they are oversized and flush in the leading edge with the trailing edge 3/16” low.
