Anybody ever use a Shocker hitch? >
Old 10-09-2020 | 10:48 AM
phughes69's Avatar
Default Anybody ever use a Shocker hitch?
All 3 of my trailer use surge brakes, so converting them over to EOH is too expensive to do to all three trailer. I get a lot of jolts in the truck when the surge brakes compress and was wondering if anybody has used a Shocker type air bag hitch. From the video, it looks like it will absorb some of the shock when the surge tongue compresses.
https://shockerhitch.com/product/sho...eceiver-hitch/
phughes69 is offline
Old 10-09-2020 | 11:00 AM
bencini231's Avatar
So you have disc brakes or drum on your trailer? I just converted my MYCO trailer with disc brakes to EOH and sourced the parts out from different vendors and came out less than buying the complete kit as well as buying a new 2 5/16 coupler to get rid of the surge brake assembly. Mine was around the $800 range for everything. I used the Hydrastar actuator, Hydrastar brake module for ford / chevy, new juction box with cord and 7 way plug, breakaway kit and titan 2 5/16 coupler. Its way better than the surge brakes all day long and well worth the money for the safer braking.
bencini231 is offline
Old 10-09-2020 | 11:37 AM
phughes69's Avatar
I have triple drums on one trailer, tandem drums on another and single drums on the 3rd trailer. At 800 ea, it gets rather expensive. I hear you about the benefits of EOH and discs and don't dispute that.
Old 10-09-2020 | 11:48 AM
bajaholic's Avatar
I have a number of people I know that have that hitch set up for their RV Campers. They all like it and say they would but it again in a heart beat. That being said, from what I have been able to tell. It helps with the bounce,(Up and down ) not the "slam" of surge breaks. So.... I am not sure if it would be worth the cost? But it would be nice to try one first hand on a surge break set up.
bajaholic is offline
Old 10-09-2020 | 12:12 PM
cigrocket's Avatar
I agree it would benefit the up and down motion but as for the shock of surge brakes I would say it would do nothing. X axis motion versus the Y axis motion. And really with the setback of wheels on a boat trailer and the weight in the rear where the engines are. Boat trailers shouldn't bounce at all. I never had a bounce problem if tongue weight and height are adjusted properly. Sorry EOH way to go
cigrocket is offline
Old 10-09-2020 | 01:20 PM
Using one of these will help tremendously with the clunking
Amazon Amazon
Griff is offline
Old 10-09-2020 | 02:55 PM
I have full disk on my custom Eagle trailer and It's as smooth as silk. The only thing I feel is the back end of the tow vehicle getting pushed down when the trailer is braking hard. I did pull the boat forward to get more tongue weight and that helped with the ride more than anything. I also added a strap off the bow to the trailer that settled down the bounce of the boat over rough roads. Of course I'm only towing about 6500lbs with a Yukon Denali.
ThisIsLivin is offline
Old 10-10-2020 | 01:05 PM
Cash Bar's Avatar
Mod Squad Enforcer
I have a Shocker. It's amazing for the bouncing and clanging, but I'm not sure it would help in a surge situation.
www.gregsellswaterfront.com
Cash Bar is offline
Old 10-10-2020 | 01:48 PM
You can feather the brakes on a tow vehicle but the scourge of a Surge brake systems that they are always trying to run over the tow vehicle.... Even semis have better control of the trailer and the truck slowing down at the same rate under braking b/c the surge system activates independently from the driver and the brakes come on harder than the pull truck is decelerating
EOH conversions may seem like a lot of money, until you hook up to one. EOH is easier on the truck, on the trailer, on the cargo ....and those in the tow vehicle
With the hitch above, I think you will run out of cushioning with the loading from the surge effect
speicher lane is offline
Old 10-10-2020 | 02:12 PM
F-2 Speedy's Avatar
some times when a serge system hits hard, its either low or out of fluid, air in the system or just wore out
F-2 Speedy is offline
