Mercury 500 EFI closed cooling
Hi
Is it possible to instal a closed cooling circuit on a MERCURY 500 EFI ?
If you have realizes this evolution, some photos, with supplier, satisfied ?
If so, lateral position feasible ?
Thanks you in advance for your leads
Yes. Did it on mine back in 2004-2005. Mounted the reservoirs in the gunnels, and painted them to match the engines. Worked perfectly. Use distilled water. Sorry... no pics! Boat literally sold within days after putting it back together.
Hello
Without aftermarket solution !!
I throught to install the parts of a 525 EFI on my 500 EFI,
but I just noticed that the heads do not have the passage of water at the exit of the heat exchanger crossover manifold !!!
Damage, that would have been simpler
Bye
Bye
