Help boat got overheated , doesn’t run right ..
Ok water pump belt broke didn’t know it until I saw smoke and temp gauge pegged …
I took it home and did following ..
changed the oil and filter , changed all the spark plugs and ignition coil. Installed block off plate and added new electric fuel pump and changed fuel filter/water separator …
boat will start fine , idle fine, rev fine while in neutral . BUT when it’s in the water and I try and accelerate it sputters and misses …
It is a 454bbc
should I check carb? compression??
It is a 454bbc
Fuel psi not enough. 5-8 is good.
I’ve worked on many engines, including marine, that ate a headgasket over heating. If bad enough can warp surfaces. Sometimes create a trough between cylinders. I’d do a compression test.
