Carb in a box question
This is the carb i got whit the engine..im missing the uper part of the box...can sombody tell me is this the right carb.the nubers on the coak horn are 80486...and1085..thank you guys
The box is for a turbocharged blow-thru application,....
So, if you don't have forced induction, you don't need the box,....
It should work if it is bigger than 700 cfm I could not find a listing for it just keep a eye on your air fuel ratio numbers how are you altering your fuel pressure under boost.
