Head size to match block bore? >
Old 08-08-2022 | 02:09 PM
Default Head size to match block bore?
Do heads need to be machine to the exact bore of the cylinder? I’m trying to determine whether certain heads are going to fit my 496 without any need for modification. I’m 060 over on the cylinder walls of the block.
Batmeat is offline
Old 08-08-2022 | 02:20 PM
No
LakeHuronPower is offline
Old 08-08-2022 | 02:51 PM
Originally Posted by LakeHuronPower
No
thank you
Batmeat is offline
Old 08-08-2022 | 04:47 PM
If you have a 2.19 intake valve most likely not.
fbc25el is offline
Old 08-08-2022 | 06:48 PM
SB
No. But if your heads are set up for a bigger bore (many aftmkt heads comb chsmber are set up for 4.47” or 4.500 bore) make sure your headgaskets don’t over hang the heads combustion chamber.
SB is offline
Old 08-08-2022 | 09:25 PM
awesome! Thank you.
Batmeat is offline
