flushing engine >
flushing engine
flushing engine
Old 05-06-2023 | 06:36 PM
Default flushing engine
Hello All
I trying to run the engine on a hose to a bravo drive with a low water pick-up, but I can't get any water to the pump. Is there another way to run the engine on a hose or does anyone make a kit to install between the suction hose. Everything is new hoses are installed correctly and I checked to make sure nothing was plugged.
Jeff
Zinger is offline
Old 05-06-2023 | 07:09 PM
Veteran: Army
Eddie Marine flush kit. Tees in before the raw water pump.
DrFeelgood is offline
Old 05-06-2023 | 10:34 PM
SB
Search oso
Perko Flush
and you’ll find many threads on how to use/modify one for proper/successful use.
SB is offline
Old 05-08-2023 | 11:41 AM
Dave M's Avatar
Veteran: Navy
Adding a sea strainer is a good investment. Makes flushing a breze.
Dave M is offline
Old 05-08-2023 | 11:49 AM
Wally's Avatar
Were doomed!
you could always just unhook the hose from the inner transom and stuff the garden hose right down the hose straight to the pump....
-Wally
Wally is online now
Old 05-08-2023 | 12:10 PM
I have 1 of these one each of my engines. Works great.
Amazon Amazon
SabrToothSqrl is offline
Old 05-09-2023 | 04:21 AM
Veteran: Navy
I believe Bam is a member here. This setup is the cat's meow.
http://www.mercruiserparts.com/898235a01-flush-kit-mcm
AmiableDave is offline
Old 05-09-2023 | 04:36 AM
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
I had one break ( plastic) and boat almost sank. It was old though...
j272 is offline
Old 05-09-2023 | 08:49 PM
I liked the idea of adding the strainer I also added a flush port to make it easier, still.
Big_Baller is offline
