Thermostat replacement
Okay, here's an easy one. I'm thinking of replacing the thermostat on my 454 Mag MPI since it is original (over 4 yrs old). Any suggestions on what part I should use? Stock MerCruiser? Somebody else's product?
Dustin Whipple already suggested that I drill 4 to 6 3/16" holes in the stat to allow the engine to run a little cooler.
Thanks,
Thanks,
I would suggest that you use only the thermastat that MerCruiser calls for. Since you have a fuel injected engine the computer adjust the fuel mixture based on the temp. If you run the engine below spec. you engine will run rich.
Dail
Dail
