Looking for info:  21 Skater w/twins. >
Old 10-03-2025 | 07:59 AM
Default Looking for info: 21 Skater w/twins.
Hi,
I just bought a "new to me" 21ft Skater with twin 2.5's.
I would like to get information and maybe talk to someone who has had this same boat.
I have questions about "Porpoiseing".
Details about my the first trip to the lake:
• Full Tanks
• Just me in the boat.
• Set of cleavers.
• Both smooth water and moderate chop.
• Speeds from 0-70 or 80mph-ish (speedo didn't work)
I launched the boat and headed out, but no matter what speed and what trim level I was at, the boat would not stop Porpoiseing.
It started small then got to the point where the whole boat was coming out of the water.
I would let off the gas, it would settle down and the process would start all over.
I played with the trim at all speeds, and in the different water conditions.
The best trim level ended up being almost all the way "in" close to #1 on the trim gauge.
Anything above that accelerated the Porpoiseing.
It made the boat not enjoyable and I just put it back on the trailer after an 2hrs
I'm looking for info or maybe get on the phone with someone who has or had a 21ft, that can give me some insite on how they ride and if this problem can be fixed.
I'm new to this site, so I don't ave the ability to private messages yet.
Please help if you can.
My next step is to get rid of it & move on.
Thank you
FT
This was just about trim level that seemed to work best.
Props that are on the boat.
Floatn Turd is offline
Old 10-03-2025 | 08:29 AM
Hopefully someone on this site can help you.
You can also check out screamandfly.com. There are a ton of outboard guys there that are very helpful.
underpsi68 is offline
Old 10-03-2025 | 09:45 AM
Hi,
I did.
And I spoke to some good people on there.
But
No one that had this specific boat w/twins.
That is what im looking for.
I will try the Facebooks and see what shakes out.
Thank you Sir
Old 10-03-2025 | 10:33 AM
If it was me, I would get on the phone with Skater.
Padraig
Padraig is offline
Old 10-03-2025 | 01:22 PM
Default Drive through it
What happens if you push the throttles forward and try to drive through it?
You may not have been going fast enough to get out of the hop range.
Markus is offline
Old 10-03-2025 | 02:21 PM
Padraig
I did and i got less than Zero help or return calls.
Everyone who had knowledge of these old boat has either died or moved on on. And since i was not in the market for a new $500,000 boat, they didn't give 2 ****s about questions.
O well.
Old 10-03-2025 | 02:24 PM
I tried that but it did not help.
It was pretty frustrating.
Someone out there had to have this same problem.
I just need to find em.
Old 10-03-2025 | 09:59 PM
Skaters hop in certain speed ranges.
Usually, you just drive through it. You may not have been going fast enough.
Markus is offline
Old 10-03-2025 | 10:04 PM
O well.
Most people have a different experience with contacting Skater.
Call until someone answers the phone, and be polite.
The answer you will get is most likely ”You need to drive through it”, though.
Markus is offline
Old 10-04-2025 | 11:05 AM
the 14.5x30 props u are running look to be mazco 3 blade os cleavers
if that what the props are,,,
the mazco OS props are real high rake cleaver props,,,,
these are full lifting props,,,,
most 21 skaters with singles run a 4 blade promax prop as their all around prop
21s like the round eared props as help settle the transom not to lift so much
might want to try different props first
as was only 9 factory twins made so not a lot of data for twins
johnmiffco is offline
