VP DP-SM Outdrive Cooling Question
I’m going to install a through-hull water pickup to attempt to solve an 8.1 cooling problem (really long story). My question is whether or not I can simply cap off the water intake pipe from the Volvo Penta DP-SM outdrive, or does the outdrive depend on that water intake for cooling?
Drives will benefit from extra cooling in the housing.
Is there an impellor in the leg, or does it use the raw water pump on the engine to draw it up?
With dedicated raw water draw, guys often plumb the drive raw water to a through hull and use it as a drive shower with a through-hull fitting.
Anyway
Here is the link to your other thread:
(Another) 496 Overheat Puzzle
after reading through you original thread with your over heating issue it sound like you replaced everything except your circulating water pump on the front of the motor you do mention that you took it off and apart and every thing looked good. I also had a similar over heating issue and went through pretty much the same process i also took my circulating pump apart and found impeller in good shape and tight on the shaft but since i already had it apart i went ahead and replaced the circulating pump and low and behold it solved my problem i can only think that under load it must be enough to allow the impeller to slip on shaft you might try replace circulation pump first before jumping through any more hoops, i know what your going through chasing a over heating issue drives you crazy good luck.
later
later
I guess there’s a chance it’s slipping. I should have scribed a line on shaft and impeller as a reference. Sure don’t see any signs of slipping. What’s another couple hundred at this point. Here’s a before and after cleaning. I had a 19 second video but it was “missing a security token”.
I have taken everything apart,
1988 pump re-circulation that is this has Vanes and is solid
the new pump vanes are about 1/4 longer and coated with what looks like some hard coating
Boat is only freshwater
112 is not bad for a sierra pump
New pair arrived late yesterday..amazon🤣
