school me on arneson surface drives..
i’ve seen the 7 m kit to retrofit a bravo one drive, but what’s involved in replacing the whole drive, i get you’d have to alter the transom, but isn’t putting a non conversion unit cheaper? whats involved? can it be done with used parts more reasonably?
Single or Twin Aplication?
I have a single ASD#8 available if its of any interest
thank you
Cougarman
ASD7 uses the ASD6 box with a different prop shaft tube and the extension boxes. Depending on your power...going ASD6 and getting extension boxes may be the best method.
Back from the Dead; '81 Scarab 38 Resto
HBlair has some good photos of the non-Bravo setup. Still uses extension boxes, but uses the inner transom mount for the extension box as a trans mount to hold the rear of the engine.
Photos at the end show inside the ext box.
Asd7 uses the larger 26spline prop shaft, vs ASD6 19spline.
ASD7 also has a build in low profile steering ram attached to the ext box side...vs requiring an extended transom mount.
Nice to have the engines aft for CG, and easy engine room change costs etc. There's often used ASD7 setups around. I think KAAMA has 2.
