Affects of weight and humidity on speed?? >
Old 05-20-2003 | 10:45 AM
ccarloss's Avatar
Question Affects of weight and humidity on speed??
Since it is near impossible to test things under the exact same conditions, are there a few “rule of thumb” formulas for seeing the affect of humidity, weight, and RPM on MPH? Basically how do each of these affect MPH? **FOR EXAMPLE ONLY** - for every 10% increase in humidity you will lose 20hp, or every 100lbs = a loss or gain of 1mph. For every 100RPM’s you will lose or gain 1mph.
ccarloss is offline
Old 05-20-2003 | 12:15 PM
bobby daniels
HUMinity takes the avalable oxgen out of the air and makes the mixture rich and there goes your power ,weight depend on hull !!
Old 05-20-2003 | 02:24 PM
HyperBaja's Avatar
100lb for 1 mph.....2500/100=25. I might actually run 75
HyperBaja is offline
Daniel
Cigarette
19
09-22-2006 11:00 AM
Bad Girl
Fountain
6
07-18-2006 09:17 AM
Craney
06-27-2006 07:52 PM
Toffen
04-11-2004 01:26 PM
FunHome
Fountain
17
09-18-2002 10:09 AM
