Go Back  Offshoreonly.com > Owners Forum > Nordic
On plane no reading of depth finder >
Old 05-22-2003 | 06:46 AM
Mr. Gov'nt
Default On plane no reading of depth finder
Anyone experiencing this: On my 28 Heat when I get on plane the depth finder does not continue to make readings it only makes readings when I am going slow. I contribute this to the placement of the transducer or whatever they call it by Nordic. I think they installed it towards the mid or bow section so when the hull is out of the water on plane the depth finder makes no reading. What does everyone think?
Old 05-22-2003 | 07:11 AM
rv
Did you look and see where it is located? If not, take a look on the floor in the engine compartment. Once you find the location I think that will answer your question why it doesn't work when on plane.
Rick
rv is offline
Old 05-22-2003 | 08:32 AM
Nordicflame's Avatar
This probably doesn't help but mine doesn't work either.
Nordicflame is offline
Old 05-22-2003 | 08:48 AM
Indy's Avatar
Member #154
Mine doesn't work either...stepped hull, not good for transducers.
Indy is offline
Old 05-22-2003 | 03:33 PM
DaveHam's Avatar
Mount the transducer just in front of the step. I've done that on two Formula's and they worked just fine.
DaveHam
DaveHam is offline
hdtvned
3
08-08-2007 07:48 PM
groundsfordivorce
08-07-2007 07:50 PM
dencam7
1
07-30-2007 12:28 PM
baja bailey
15
07-25-2007 12:20 PM
speedchangesyou
4
08-02-2005 01:33 PM
