How to add fluid to the liquid Gaffrig? >
Old 06-08-2003 | 02:39 AM
skygod's Avatar
Default How to add fluid to the liquid Gaffrig?
Anyone do this? What type of fluid?
Baja History
2000 29 Outlaw 2x454 mags (sold)
2000 25 Outlaw 502 (moved up to 29 OL)
1998 232 Islander 7.4 (got the 25 OL)
Tow Rig
04 Excursion EB PSD 4x4 6" lift 35's
MY PICS: http://community.webshots.com/user/skygod73
skygod is offline
Old 06-08-2003 | 08:55 AM
H2Xmark's Avatar
it uses glycerin, call Gaffrig they have the fluid, should be a rubber plug in back of gauge to fill
H2Xmark is offline
Old 06-08-2003 | 12:34 PM
OSO Member Too Old once said the that glycerin can be obtained at a normal drug store.
29 OUTLAW is offline
Old 06-12-2003 | 03:23 AM
skygod's Avatar
Thanks!
Baja History
Tow Rig
skygod is offline
Old 06-12-2003 | 05:13 PM
Erie Desire's Avatar
Just don't use Nitro-Glycerin.....one big wave....and......KABOOM.
Erie Desire is offline
Old 06-13-2003 | 09:35 AM
kbush2
you can obtain the fluid from gaffrig for around 30 dollars including shipping. there was enough to fill the speedo at least twice. first make sure that the yellow seal is seated properly. to check, spin off the colored bezel and remove the face plate. the seal seats in between the flange on the face plate and the gauge itself. after replacing, the glycerin fill port, depending on the gauge, is either at the top, or just above the speedo cable plug in, remove and fill. the trick is to get all of the air bubbles out. may have to play with it in order to achieve. according to gaffrig, there should be a small pea size bubble remaining. good luck....ken 342 boss....speed dosen"t kill, boredom does!!!
302Sport
02-22-2008 07:55 AM
SHAKEN Not Stirred
29
06-26-2003 01:05 PM
skygod
2
06-08-2003 10:55 PM
BAJA WILL
06-26-2002 06:04 PM
