Wanted: Set of speedmaster props >
Old 07-02-2003 | 08:31 AM
Default Wanted: Set of speedmaster props
Anyone have a set of 16 or 17 x 24,25,26 etc? Can be 3 or 4 blade 19 spline 6 inch hub for number 3 speedmaster.
KenP is offline
Old 07-02-2003 | 08:36 AM
KiloKat's Avatar
KiloKat
Check with John Tomlinson @ TNT. 305-931-3157
Everything Runs Better On Alcohol
www.nautiboats.com
KiloKat is offline
Old 07-02-2003 | 09:07 AM
Mbam's Avatar
Offshoreonly Advertiser
I have some,
954 545 8681
Mbam is offline
Old 07-02-2003 | 09:27 AM
Official OSO boat whore
Believe it or not...there was a PAIR on ebay the other week. Went for $250.
Cord is offline
Old 07-03-2003 | 12:39 PM
DEVIL MAN
I have a pair in mint condition....three blade for a speedmaster drive...small shaft....17.5X28...just e-mail me if you are [email protected]
DMan
Old 07-03-2003 | 01:49 PM
BURNSMAZZ's Avatar
I need some too,I've been trying to find some 17.5x31 or even 32s with small shafts,and haven't had any luck.
BURNSMAZZ is offline
Old 07-03-2003 | 02:00 PM
X-Rated30's Avatar
Ken:
I know you want a 6 inch hub, but don't worry about going to the short hub. I had a pair of bronze or brass (I forget which) spacers fabricated to go on behind the prop and in front of the nut so I could try a pair of 3-blades. Works fine. It was only about $40 to have them made. Not fre, but considering the 3-blade props cost about 1/3 as much as the 4-blades, it is cheap enough just to try a pair out.
P.S. -- Still had to go with the 4-blades.
X-Rated30 is offline
Prater
Wanted
0
10-27-2008 01:16 PM
Viperfitness1
Wanted
1
07-13-2008 04:20 PM
fstboater
04-20-2007 05:52 AM
boatman747
4
03-23-2006 05:26 AM
autoap
06-11-2005 06:09 PM
