Difference between Formula 382 Fastech and Formula 382 SR-1 >
Old 09-07-2003 | 08:34 AM
Default Difference between Formula 382 Fastech and Formula 382 SR-1
Hi!
I am stilll looking for a Formula.
How is the ride in a Formula 382 SR-1 compared to a Formula 382 Fastech? I know its approx. 5 mph slower, but how is it running at high seas, corners, cruise, etc?
Or should I buy a second hand 353 Fastech if I can not afford to buy the 382 Fastech? A 382 SR-1 is normally slightly less expensive than a 353 Fastech.
Cheeers, Toffen G - Norway
Toffen is offline
Old 09-07-2003 | 08:43 AM
Formula Outlaw's Avatar
I personally feel a conventional "deep vee" can be "trusted" more than a step-bottom. The knock on step bottoms is that they will tend to "slide around" on you much easier. It only stands to reason, the hulls are "areated", thus less friction to prevent slides. Yes they are faster, but if your running along at speed, spot a debris in the water immediately ahead of you, your natural reaction is going to be to haul the wheel over hard. That has been the cause of quite a few accidents in step bottom hulls. I would buy the 382 SR1, and the money I saved, I would put in the motors. I have heeled my 311 SR1 over, DRASTICALLY, twice to avoid debris, and it felt like it was on rails. I have driven 7/8 step bottoms (various makes), and have turned them semi-sharply to feel for myself, and did not like it. Just my two cents worth. Troutly probably has good feedback on this issue.
Formula Outlaw is offline
Old 09-09-2003 | 10:37 AM
cuda's Avatar
If it was me, I'd get a 353 Fastech. Nice big boat, but still quite a bit faster than the 382 in either configuration. As far as the step hull, just take the advice on how to drive it. There is PLENTY of advice on OSO about it.
cuda is offline
Old 09-09-2003 | 01:47 PM
Default 382 Fatech and 382 SR-1
Hi!
Thanks for the good advise!
Still looking for a Formula / Phantom Classic.
Cheeers, Toffen G
Toffen is offline
Old 09-10-2003 | 03:54 PM
Just spoke with a Formula tech rep on a 353 at our shop, They have a customer who purchased a 382 Fastech poker run edition and is putting in sterling 1200's, how fast do you want to go?? But the 353 has to be the best handling of the formulas BY FAR!!!
ceich35 is offline
Old 09-10-2003 | 04:02 PM
Default 382 Fastech & 382 Sr-1
Hi!
My current boat runs 78 mph, so it should be faster than that. Ideally around 90 mph. I presume the 353 is the boat to choose to manage this speed.
Cheers, Toffen
Toffen is offline
Old 09-10-2003 | 04:06 PM
With stock engines and overall driver FUN YES!!!
ceich35 is offline
bripar77
5
04-25-2009 05:20 AM
partymedic
04-04-2008 12:56 PM
MooseKnuckle
06-05-2006 06:31 PM
sea-crit
Prop Talk
3
05-09-2006 09:41 PM
bripar77
10-05-2002 06:15 AM
