Boat speeds w/ this power ?? >
Old 12-16-2003 | 08:36 AM
Chris288's Avatar
Default Boat speeds w/ this power ??
what are the approx. speeds of these boats and power ??
28 pantera w/ single hp 500
288 sunsation w/ 496 and 496 HO
27 formula fastech w/ 496 HO or 502
baja 275 w/ 496 HO
26 and 28 powerquest w/ 496 HO
27 fountain w/ 496 HO
Chris288 is offline
Old 12-16-2003 | 08:57 AM
Rocky's Avatar
The FORMULA Fastech will be 60-63mph per the factory spec guide. I have found FORMULA's speed estimates to be a little conservative and would expect 63-65mph.
Rocky is offline
Old 12-16-2003 | 08:59 AM
CustomRigger101's Avatar
i was going to say.. 68-73.. on good days..
CustomRigger101 is offline
Old 12-16-2003 | 09:03 AM
BRUCE SEROFF's Avatar
Pantera 28 Full pleasure set up with 500hp 70-73 MPH
BRUCE SEROFF is offline
Old 12-16-2003 | 09:08 AM
Chris288's Avatar
I'm pretty sure the baja will do approx. 67-68,,, and the sunsation should do 71-72...
Chris288 is offline
Old 12-16-2003 | 09:43 AM
phastang's Avatar
PowerQuest 260 with 496 HO should run 65-67 MPH. Mine went 63 with a stock 454 MAG at 385HP. Now it's a little faster.......
phastang is offline
Old 12-16-2003 | 10:39 AM
Tim G.'s Avatar
Performance Boat Center
What's all this single talk???
Attached Thumbnails Boat speeds w/ this power ??-transom-drives0001.jpg
Tim Gallagher
Performance Boat Center-FL
[email protected]
954-809-8739
Wright Performance, MTI, Cigarette, Sunsation
Tim G. is offline
Old 12-16-2003 | 11:03 AM
BillR's Avatar
OSO Moderator
The PQ 280 w/ a 496HO should run 68 - 71 mph.
My old one w/ a 502 would run 68 - 69 and every so often it hit 71.
Reckless288's 288 Sunsation w/ a 496HO runs 69 max but 67 - 68 everyday.
BillR
'00 Scarab Sport 302 CC
'02 Cigarette Top Gun TS
'02 PQ 340
'00 PQ 280
'98 Scarab 22
'97 Baja Outlaw 20
'72 Checkmate
'65 Glastron
BillR is offline
Old 12-16-2003 | 11:09 AM
Chris288's Avatar
HMMMM.. if a 26 power quest only does 66-67,, how does a 28 do 70. just curious...
Chris288 is offline
Old 12-16-2003 | 11:14 AM
phastang's Avatar
Chris-The 280 has a step hull and the 260 is a traditional bottom. I was just guessing on the 26 at 65-67. I would bet with the right setup, a 260 with an HO would run 70. I test drove a 280 before i bought mine with a 500 HP and it only ran 72 on the GPS.
phastang is offline
