Shift Cable Bellow
The drive has to come off and the shift cable has to
be undone from the bell housing and transom assembly.
Then you undo the clamp that is pinched/crimped over
the shift cable (keeps water from leaking thru the shift
cable) and undo the stainless steel clamp on the end
of the bellow that secures it to the transom assembly
and slide the shift bellow off and put the new one on.
I would highly recommend checking/changing the
shift cable also if you had water leaking in. Hope this
helps.
helps.
DrFeelgood
Drives and Lower Units
5
11-05-2007 09:42 AM
