New cockpit flooring? >
Old 04-08-2004 | 12:11 AM
Danny_Ocean
Default New cockpit flooring?
I'm tearing the carpet out of my cockpit and would like to replace with a hard, non-slip surface (or something that can be painted non-slip). Sub-flooring is currently 1/2" plywood with a soft spot outside the cabin door.
Any suggestions on what can be layed over the existing sub-floor?
Thanks in advance,
D. Ocean
Pompano Beach, FLA
Old 04-08-2004 | 04:50 AM
P Offshore's Avatar
Doller Offshore usually has a big roll of the Pirelli rubber flooring used in Cigarettes and they will cut to length needed.
P Offshore is offline
Old 04-10-2004 | 01:21 PM
florida gator's Avatar
Where is Doller Offshore?
Danny, what are you going to do about the soft spot in the floor? I have the same problem and have contemplated redoing it myself. I wasn't sure how big of a job it was.
florida gator is offline
Old 04-10-2004 | 02:43 PM
Indy's Avatar
Member #154
http://www.offshoreonly.com/forums/s...threadid=73262
Indy is offline
Old 04-10-2004 | 11:29 PM
Danny_Ocean
Doller Offshore is in Ft. Laud, I believe.
The soft spot is about 12" x 12", right in front of the cabin door. Subfloor is 1/2" plywood. I'm going to chisel/cut the soft spot out and replace with a new piece of 1/2" Starboard (www.tacomarine.com). However, if I can find flooring that's rigid enough, I'll just overlay that in place of the carpet.
D. Ocean
Pompano Beach, FLA
Powerboat713
9
01-09-2008 07:43 PM
34SUTPHEN
02-27-2007 12:08 PM
dreamer
05-27-2005 08:45 AM
jawbreakerkid
Cigarette
13
02-18-2004 05:22 PM
Zitto111
02-17-2002 02:37 PM
