Problem with IMCO dual ram steering >
Old 04-09-2004 | 08:24 AM
bglz42's Avatar
Default Problem with IMCO dual ram steering
I just bought a single engine boat with an IMCO dual ram steering system, hydraulic to the helm. I'm getting no power assist at all. Feels the same, running or not. I called Dino at Teague and Ron at IMCO, and though they were helpful (I already drilled the orifice, cleaned the filter), were stumped... This morning I replaced the power steering pump, and still no assist. There's no air in the system, Ron told me how to detect this. I checked the hoses against the schematic, and it seems to be plumbed right. The previous owner just got used to it, but both Dino and Ron told me the steering should be "one-finger easy". It's DEFINITELY not. More like TWO -FISTED! Makes docking difficult to say the least! Any ideas? Something I've missed?
bglz42 is offline
Old 04-09-2004 | 09:54 AM
You've probally checked this, but I once had a similar problem. The hoses were reversed on one side (rams were fighting each other). Good luck!
azlineman is offline
Old 04-09-2004 | 11:06 AM
I HAVE THE SAME SETUP.STEERING IS DEFFINATLY NOT ONE FINGER STEERING.BUT I ALSO DONT NEED BOTH HANDS.WHEN THE BELT FLEW OFF LAST YEAR AT 85 I KNEW IT.
z.zuperboat is offline
Old 04-09-2004 | 07:10 PM
Mr Gadgets's Avatar
Charter Member #601
I have WPM steering and it was hard. Check to see if there is any binding in the helm shaft. Also check to see which model helm you have. That makes a big diff.. or do a lock to lock test.. 2 to 3 turns, end to end.. if it is less than that you may have the wrong helm.
You dont have a kinked or colapsed hose? Does the drive move back and forth freely? You could have binding that you are trying to over come. If it is the same effort, with and with out motor running then look at psi in system. This is high pressure so be careful. I made up a tee and added to my high psi side with a gauge to see what was happing.
Well I have exhausted my brain.. good luck!!
Dick
PS any ??? email or pm me.. be glad to help. I know I was there once.. and yes my buddies Imco system is truly one finger!!
Mr Gadgets is offline
25 hors la loi
5
06-14-2008 03:37 PM
eliminator25
Drives and Lower Units
4
05-08-2008 03:37 PM
donzi23
8
07-25-2007 02:11 AM
R Addiction
7
05-27-2007 07:49 AM
bglz42
34
04-14-2007 02:05 PM
