having idle problem with this cam >
Old 04-22-2004 | 04:58 PM
timucin's Avatar
Default having idle problem with this cam
i was expecting around 1000rpm idle but it cant work under 1500 properly, do you think this cam is hi for 1000rpm idle?
520 cu in.8-71 blown bb
timucin is offline
Old 04-23-2004 | 12:04 AM
Thats a BIG cam for 520 CI. What's the base ignition timing set at???? More timing will help it idle better.
Griff is offline
Old 04-23-2004 | 09:12 AM
mopower's Avatar
Toxic FORMULA
Went though the same thing with my 540's last year Changed cams over the winter. I didn't have enough vacuum at idle to pull fuel once I put it in gear and the rpms dropped some more .
NOTE: THESE WERE RECOMMEMDED BY COMP CAMS
mopower is offline
Old 04-23-2004 | 10:03 AM
Official OSO boat whore
Do you have the idle set so high that the butterflies are open past the slot? I'm wondering if some carb work by one of the gurus wouldn't help.
Cord is offline
Old 04-23-2004 | 05:04 PM
timucin's Avatar
sorry bros, i worked a bit too much last week to finish this project .
problem was valve settings, fixed and everything is ok now, idles around 900rpm
thnx for ideas and help
timucin is offline
ak_boater
6
07-03-2007 12:51 PM
tanner
6
04-25-2007 06:13 AM
stuball
1
08-06-2006 10:49 AM
BajaRunner
13
10-26-2004 11:04 AM
Perfectmix
12
10-21-2004 08:32 PM
