Intake valve length? Merlins... >
Old 04-26-2004 | 07:50 AM
dyno's Avatar
Charter Member #655
Default Intake valve length? Merlins...
I need some intake valves for my merlin oval ports anyone know what the length is off the top of your heads????
If your boat has a sail do you ride a horse to the ramp?
dyno is offline
Old 04-26-2004 | 09:14 AM
cstraub69@comcast
If they are the 3/8" stem stuff, then stock length of 5.225", most of the 11/32" stem stuff is a .100" longer.
Chris
Old 04-26-2004 | 09:24 AM
dyno's Avatar
Charter Member #655
thanks man you rock!!
dyno is offline
Old 04-26-2004 | 09:25 AM
I'M SURE YOU KNOW THAT DEPENDS ON WHAT INSTALLED HEIGHT YOU NEED BUT FOR AN INSTALLED HEIGHT OF 1.925-1.950 WHICH IS WHAT YOU WOULD NEED FOR A HYDRAULIC HYDRAULIC ROLLER OR FLAT TAPPET A VALVE OF 5.250. MOST MANUFACTURERS MAKE THEM IN 5.300 YOU MAY NEED TO RUN A SPRING CUP TO GET YOUR INSTALLED HEIGHT. A SPRING CUP IS A GOOD IDEA ANYWAY TO KEEP THINGS STRAIGHT. GOOD LUCK LAZ MESA WWW.MESABALANCING.COM
MESABALANCING is offline
Andy
10
03-19-2008 03:58 PM
Grog
11
01-31-2008 04:27 PM
speedygonzalez
2
07-02-2007 08:53 AM
Hot Boat
11
05-31-2003 09:48 AM
kathycool
12
03-22-2003 07:40 AM
