Depth finder how to set >
Old 05-01-2004 | 04:19 PM
jeff bratton
Default Depth finder how to set
how do you set the Graffrig depth finder? it keeps sounding off. Thanks Jeff
Old 05-01-2004 | 04:35 PM
Downtown42's Avatar
no owners manual? Sounds like your shallow warning alarm is set.
Downtown42 is offline
Old 05-01-2004 | 06:52 PM
jeff bratton
no paper on depth finder. shallow alarm is going off, not sure how to set it. It was going wild in 100' of water. thanks Jeff
Old 05-01-2004 | 07:33 PM
Downtown42's Avatar
Mine never worked good. Transducer is epoxied into bildge. I read some where that you will never get a good working one due to the hull composites on Fountain unless you drill into the hull and thru-it. I have a Lowrance and sent the brain box to them, ck'd out fine so I bought another transducer and that did the same thing.
Old 05-01-2004 | 07:34 PM
US1 Fountain's Avatar
Ginger or Mary Ann?
They default to 10 ft when powered up. Push and hold the little button in the center to adjust the depth setting and/or to turn on/off the alarm.
US1 Fountain is offline
Old 05-01-2004 | 07:36 PM
Downtown42's Avatar
You should be able to hit alarm button to disable/turn off. Call Livorsi if no one else chimes in here.
Old 01-26-2005 | 05:16 PM
50boat's Avatar
Default Re: Depth finder how to set
yea mine does the same thing, and will not read when moveing more than 10 mph. it will read 100ft when only 3ft. and so on
50boat is offline
hdtvned
3
08-08-2007 07:48 PM
groundsfordivorce
08-07-2007 07:50 PM
dencam7
1
07-30-2007 12:28 PM
baja bailey
15
07-25-2007 12:20 PM
speedchangesyou
4
08-02-2005 01:33 PM
