Gas Going Up! Prices Going Down. >
Old 05-08-2004 | 09:16 AM
HOUSTONPROP's Avatar
Post Gas Going Up! Prices Going Down.
GET THE EXTRA PERFORMANCE YOU WANT!
Lab finish your prop!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
satin finish> 3 blade>150.00 new or damaged
satin finished 4 blade>199.00 new or damaged
polishing add 25.00 per blade.
ACCLERATOR design add 50.00
Bravo-Rator 4bld design add 75.00
CALL, place order/
send prop in when you need to.
get 25.00 off price.
HOUSTONPROP is offline
Old 05-08-2004 | 09:36 PM
Eternal Warrior
Darin, If all goes well I'll have bravo to send your way. I'm supposed to be able to up my boat next weekend so I can do some testing. What is the turn around time like right now?
Old 05-08-2004 | 11:45 PM
Default turn around time/
all props received will be 5 working days in the shop ,you can always speed up shipping if you want.
in all honesty we have props there that have been there a month.
we have been buried in props,its unbelievable.
but this is driving me crazy,we are going to start working much later in the evening,we will be caught up
where we will be able to do the props and ship back in 3 to 4 days like last summer.WE cannot and will not have props hanging around much longer.NO MATTER WHAT IT TAKES.
Thanks very much ,Darin
Old 05-09-2004 | 09:33 AM
Eternal Warrior
Sounds good to me. I'll give you a call after my testing and we can talk about the specifics. With all the good things I hear about your work I'm looking forward to see what you can do. I'm in desparate need of good service experience!! Thanks!
Old 05-09-2004 | 09:46 PM
Blewbyyou's Avatar
Darin,
Will these prices be good for the prop I shipped to you friday? What do you think the turn around time will be for my prop? (3 blade mirage with polished finshed converted to ACCLERATOR design ) $275.00???
Paul
Blewbyyou is offline
Old 05-09-2004 | 11:05 PM
26sonic's Avatar
darin what is the bravo rator prop and the cost to make my stock 24p bravo 1 into one ?
26sonic is offline
Old 05-10-2004 | 12:33 PM
26sonic's Avatar
ttt
26sonic is offline
Old 05-10-2004 | 07:08 PM
Question external warrior/and
External Warrior ,sounds good to me give me a call when your ready.
Paul/blewbyyou the above prices started on Mothers Day.
SONIC26 >Its best if you send me your number and Iwill be glad to call you,then we can PropTalk and see just what you want and need.
Thanks ,Darin
Old 05-10-2004 | 11:42 PM
Have you ever done a Ballistic prop? It is a somewhat thin blade to start with, and it has a squared off tip with a lift to it. I have a 2102 VIP with a new 350 MPI. I used to have a 260HP 350 in it and ran 56MPH and 4600. With the same prop and this new motor, I am running 4850rpm to 4900, and running 61mph. I am very happy with this, but always like to run as fast as possible. I have a 21P Ballistic prop now. My outdrive is about a 1.62 Alpha outdrive. I wouldn't mind running closer to 5000rpm, to get max speed, but I can't afford to lose hole shot! Don't quote me on the 1.62, but I am pretty sure. I know it isn't a 1.7 or 1.5... it is more like a 1.62 or something similar to that.
justinVIP is offline
Old 05-10-2004 | 11:50 PM
Red face Justin VIP
Yes we repair these props they also have a four bld out.
They are very hard to get the wrinkles out after they are damaged ,but we do ,it just takes a little longer to work on them,I personally like the prop,They perform good.Call if you need to ,later Justin.
Darin
nova26
06-11-2008 05:27 AM
Superbabi
Superboat
6
09-07-2005 10:56 AM
CAP071
08-22-2004 06:04 AM
mpally
02-06-2003 05:25 PM
Team V
03-17-2002 10:28 AM
