Seized Bravo 1 Drain Plug
You will need a small 3/8 impact gun and a tight fitting to the drain plug screwdriver socket. Square up to the drain plug with the impact gun and give it small bursts, let the drain plug feel the impacts and I believe it will release. The snap on man sells the correct socket. Buy a drain plug and bring it to the snap on truck for an exact fit.
Good luck
Ed
Good luck
Ed
Originally Posted by gusman
Use an impact driver, the type that you hit with a hammer. Also try pb blaster its the best penetrant there is.
Hot Boat
2
01-14-2003 07:57 AM
