Plugging outdrive holes/what to use? >
Old 05-24-2004 | 09:48 AM
causin trouble's Avatar
Default Plugging outdrive holes/what to use?
I am putting nose cones on my bravo out drives with duel water pick ups.
I am concerned about corrosion /Hydramotive eng told me to plug 2 -3 of the upper holes by tapping and inserting hex plugs. the boat is kept in the water in summer although cleaned every 3 weeks I still am concerned about metal to metal corrosion,also I am plugging the lower holes before the nose cones go on.. what type of plugs should I use stainless/brass/plastic....
causin trouble is offline
Old 05-24-2004 | 10:00 AM
mopower's Avatar
Toxic FORMULA
Default Re: Plugging outdrive holes/what to use?
I'm going to do mine with stainless after getting wood jammed in there then clogging the flex hose thru the transom assy. , but then I trailer mine and it's not left in the water.
I would think plastic would be ideal if you can find some. No problem with dissimilar metals.
mopower is offline
Old 05-24-2004 | 05:53 PM
A transom water pick-up would be the best way to go IMHO -- Epoxy over ALL holes when you blend the nosecone. Otherwise, Thread a piece of aluminum rod, cut it off short and slot it so you can screw it into the holes you want to plug and have tapped to accept it, and blend over with the filler when installing the nosecone. --- Jer
jpclear is offline
Old 05-24-2004 | 06:10 PM
mopower's Avatar
Toxic FORMULA
Gee , JP , you sound like you know what your doing
mopower is offline
Old 05-24-2004 | 09:49 PM
THANKS JP
Some times the simple things are staring you right in the face......
Must be working to long at the J.O.B.....brain cramps
Old 05-25-2004 | 04:36 PM
aero-offshore's Avatar
Yea , because if you don't, every spring, if you live in the north, you will have to re fill the crack that the damn frozen water leaves.
aero-offshore is offline
Old 05-25-2004 | 10:35 PM
Official OSO boat whore
If you really are concerned about corrosion, be forwarned that aluminum and stainless are dissimular metals. Maybe you could use some annodized an plugs.
I have used epoxy in the past with mixed results. The first time I used sea bond, and it didn't hold. This time I used the sticks of plumbers epoxy. It better hold this time.
Cord is offline
Old 05-26-2004 | 01:00 AM
The anodized stuff doesn't hold up very well in the water either. I've got one season on my drive shower with an fittings and they look pretty crappy. Most of the anodizing wore off when I had the boat in the water at LOTO for 10 days last summer.
Griff is online now
quadracr
Detailing, Painting, & Fiberglass
1
04-13-2008 12:07 AM
Danny_Ocean
8
02-13-2004 11:04 PM
XCAV8
6
06-06-2003 11:24 AM
Intolerant1
2
06-16-2002 02:05 PM
