Dirty drive oil, what does it mean??
1990 Bravo 1s. 1 is fine, the other is very dirty. When I drained them I drained through a paint strainer. Neither drive had any pieces, nor anything on the plug magnets except some dust.
What would cause the dirty oil? I am pushing about 650hp in each motor. I have drive showers.
If a rebuild is needed what is the best way to go?
Originally Posted by stecz20
how often do you change the drive oil????
every season or 50 hours
is it dirty as in dark?
or diry as in MILKY?
is it hte port side or starboard?
is the one that is running counter rotation? I heard counter roating is harder on parts. Maybe its the cause?
just a thought
This Cat is trying to keep up with the Big Dogs
For $12, get it analyzed. www.analaboratories.com. No affiliation, just happy customer. Other places are http://oilguard.com/oil_analysis_prog.php, or www.blackstone-labs.com.
Sounds like it might be clutch getting ready to let go. I had similar finding in one drive only, but I had big time metal shavings in mine. Found a twisted prop shaft and vertical shaft in the lower. Have replaced upper and lower with Max Machine Worx, but have not disassembled the spent upper yet to see exactly what the problem was (besides the 950 H.P. and heavy throttle hand of the previous owner!).
Canada Jeff
Drives and Lower Units
10
07-19-2007 02:38 PM
jeff32
06-28-2006 08:48 AM
Velocity Tom
07-16-2003 10:13 AM
