Alpha shift cable help >
Old 06-27-2004 | 02:43 PM
glassdave's Avatar
Neno the mind boggler
Default Alpha shift cable help
anybody know where i can get the cable clamp and end adapter for merc alpha shift and throttle. i switched from the stock assemblies to 3300c extreme cables. the stock cables had a molded plastic end and a through bolt that held the cable jacket. my new cables have the standard 10-32 end and a shouldered jacket end. i think i can just get threded hiem(sp?) joints for the carb cable but how do i adapt the housing mount to the through bolt style and the shifter end? hope this pic explains my situation. thanks all.
Attached Thumbnails Alpha shift cable help-picture-004.jpg   Alpha shift cable help-picture-005.jpg
08 OPA High Points Champion
glassdave is offline
Old 06-27-2004 | 02:47 PM
glassdave's Avatar
Default Re: Alpha shift cable help
that bolt just above the cable with the nylocks on it is where i need to put the cable. just below that is one of the stock merc style fittings (its the rear cable and was replaced with a stock unit. this is an alpha with the ignition interupter).
Old 06-27-2004 | 08:31 PM
Mbam's Avatar
Offshoreonly Advertiser
Morse & Teleflex sell a kit (palstic). West, Boat US, Overtons should all have it. If you are stuck let me know and I can get you one. $12 or so sticks in my mind for both cables.
Mbam is offline
35 White Lightning
Fountain
2
11-07-2008 06:38 PM
rrentsch
Powerquest
13
11-06-2007 02:56 PM
DrFeelgood
Drives and Lower Units
5
11-05-2007 09:42 AM
atthelake27
5
07-23-2007 08:09 AM
obnoxus
0
05-15-2002 06:18 PM
