What prop do I need? >
Old 07-06-2004 | 07:59 AM
Default What prop do I need?
I the middle of a motor change and I need help with a starting point for a prop.
502, 550hp carb motor
Bravo 1.50 gears
25 Checkmate, not sure of the weight
Shah Mat is offline
Old 07-06-2004 | 08:08 AM
Aggressor 25's Avatar
Default Re: What prop do I need?
My best guess for a starting point would be a 26 Bravo or 25 Hydromotive. What is your Max RPM (rev limiter) going to be set at?
Ty
Aggressor 25 is offline
Old 07-06-2004 | 08:18 AM
dlbCheckmate's Avatar
I run a 25 Hydromotive on a 251 convinsor. The hydromotives seem to work better on the checkmate's as far as stability and ride. Good luck. PM me if you want to talk about specifics. Dave
dlbCheckmate is offline
Old 07-06-2004 | 09:09 AM
Ty
Rev limiter??? What's that?
I bought a used T-bolt system (Dist, harness, module) for this thing and it wasn't part of the deal. I do know they are high dollar from Merc.
I know I will need one too save the motor during air time but is it necessary for the ignition system to work? I would like to get the boat wet again before the end of July
Shah Mat is offline
Old 07-06-2004 | 08:06 PM
got that boat back together yet??
Thunder32 is offline
Old 07-06-2004 | 10:36 PM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
Send a message to [email protected]
Eric Garrett, very good friend of mine, formerly here on the Potomac, now lives in TX.
They had a 1989 Checkmate 251, with 500HP, bumped up to 565HP.
I am pretty sure his favorite was a worked 28 Hydromotive.
Sydwayz is offline
Sick Stinger
Velocity
9
02-07-2008 11:39 AM
FlyFast
1
08-06-2004 10:22 AM
boatinbill
07-26-2002 09:58 AM
MIKEHTMSR24
07-22-2002 03:18 PM
MIKEHTMSR24
0
07-22-2002 01:40 PM
