Merc 502 MPI Tach bounce >
Old 08-14-2004 | 06:21 PM
Default Merc 502 MPI Tach bounce
One of my engines has a bounce in the tach at idle up to about 2500 RPM. I don't detect a miss and it doesn't seem to effect performance. Mechanic scanned it- no codes, compression OK, changed to plugs- still there. Any ideas?
ctuck0659 is offline
Old 08-14-2004 | 06:29 PM
OldSchool's Avatar
Default Re: Merc 502 MPI Tach bounce
Check your electrical connections
OldSchool is offline
Old 08-14-2004 | 07:08 PM
Thought about that- easier said than done of course but hopefully that's all it is-
Old 08-15-2004 | 06:26 PM
gaffrig
Old 08-16-2004 | 05:00 PM
Thanks- I'll start there...
Old 08-16-2004 | 07:58 PM
US1 Fountain's Avatar
Ginger or Mary Ann?
I had exact same symptons a couple yrs ago. Removed and cleaned the wire connections on the back of the tach and also flipped the 4-6-8 selector switch several times. Solved my tach bounce.
US1 Fountain is offline
Old 08-16-2004 | 10:59 PM
Excalibur502mag
I am having the same problem. Please let me know what you find out.
US1, could you please explain what the 4-6-8 selector switch is?
Old 08-17-2004 | 06:31 AM
GLH's Avatar
GLH
Short or bad ground somewhere
GLH is offline
Old 08-17-2004 | 07:07 AM
Ginger or Mary Ann?
A switch on the back of the tach that corresponds with the # of cyls. your motor has.
fastech
7
04-18-2008 03:22 PM
anotherdimension
20
09-30-2007 03:28 PM
migpilot
4
06-17-2006 08:56 AM
Krumbsnatcher
5
08-16-2005 10:29 AM
US1 Fountain
9
08-29-2002 04:15 PM
