Vacu flush toilet
The flushing water [ for wee only ] stopped making it to the toilet. Does the water come from the water holding tank or back at the pump itself, ther seems to be a little holding tank at the pump. Thanks in advance for any help Daryl
The water comes from the holding tank. The small "tank" by the pump is an accumulator tank that is pressurized with air. It allows steady water flow without working the pump every 5 seconds.
Fresh water flushes the vacu-flush head. On the 2005, my pedal doesn't pull up to fill like they say. I have to push down part way.
The system seems to work great. It's worth swallowing your pride and reading over the dreaded "instructions" on this thing. It's not all obvious how it works.
Good luck - Jerry
Good luck - Jerry
I know this is an old thread but i need to learn about the vaccuum flush system. My 47 doesnt seem to have any holding capacity, almost like there is no tank, just lines. Its a 97 so it must have a tank but i dont know where it is. The water supply comes from its own thru hull, not the tank like others have said on this post.
Does anyone have instructions?
Your right, its a macerator not a vac flush, sorry
Is there 1 line from toilet to tank and another from tank to cleanout or just 1 line with a T?
Is there a valve to close toilet line at pump out to prevent vaccuum leak at toilet?
ed
EDIT: I am sorry for the long post, I started typeing and explaining and then realized i was way to in depth, but who knows someone might need it.
Your Vacu flush works one of 2 way 99% of the time.
1. Freshwater tank, pump/accumulator, that feeds all feash water and a line to the head.
Head then uses fresh water to flush and is sucked to the holding tank.
2.Pump connected to through hull fitting, that feeds head river/ocean water to flush with, and then the head pumps to holding tank/ masarator
Most vacu flush systems have 2 holding tanks. technically speaking. the first is the VACUUM Generator. its a small tank, that is where the vacuum is built up at, with the pump sitting on top. similar to the picture below. The pump sucks the waste through to Duck bill valves (allowing a vacuum to be built up in between the head and the small tank), and then pushes it through two more duck bills on the back side keeping the holding tank from back up tot he pump its self. So a vacuum is built up, you flush/open the valve at the head, and everything is sucked into the first little tank at the vacuum generator, and you here the little pump going. While its creating the vacuum for your next flush its, also pumping the waste it grabbed the last time thought the duck bills, the pump, and then the other ducks, and then to the waste tank. The poop/paper, what ever is actually snowshed and pumped thought a plunger style pump, that is driven like a old school choo choo train arm connected tot he motor.
once a certain level of vacuum has been reached, a plunger style switch is triggered as the vacuum is pulling the plunger away from the switch. Below pic is the switch its self. This is also the MOST COMMON problem with a constantly running vacu flush pump (that and lose of vacuum from a leak.) also note this is adjustable so you can select how much vacuum you system has. to much will splatter when you pp that valve at the head, to little does not suck your stuff all the way to the tank.
the duck bill valves i was talking about 2 on each side of the pump, as these wear out they dont seal good and thus you loose your vacum faster. triggering the system to kick on again.
